EmbeddedBlue Transceiver AppMod Question????
I am using the·EmbeddedBlue Transceiver AppMod on a 2p40.· I need to utilize all the possible pins.· The way I have my EmbeddedBlue Transceiver AppMod set up I am only using PIN 0 which is used to receive data from the other bluetooth device.· I need to know what pins i can utilize without harming the EmbeddedBlue Transceiver AppMod.· It does menthon not to use PIN 5 as an output, but I was wondering if there were any other I shouldn't use?
Thank you,
Justin
Thank you,
Justin
·· I believe these questions were answered via a call to Tech Support today.· Can you confirm?· The manual shows exactly which pins are used by the EB500 on page 137 of the PDF.
