Method of Creating "Outline" gerber files.
Hey Everyone,
I'm working on an·PC/SX controlled CNC router for fabing PCBs.··I would like it to accept Gerber Files.· I can handle all of this, but I do have one problem.· I use ExpressPCB for all my layouts, and I can find nothing on making outline gerbers out of .pcb files.· I'm thinking that if I print, then scan it in, and save as a jpeg/bmp; I could then use somekind of "color recognition" to recognize the edge of a trace, and create a line that follows the outside of the trace, and from there, create the gerbers.· Does anyone know of a current program to do this or somthing similar.· Just trying not to reinvert the wheel, I hate doing that.
crgwbr
NerdMaster
For
Life
crgwbr
NerdMaster
For
Life
Both have free versions. As always, Google is your friend.
Rick
Thanks.
NerdMaster
For
Life
One is to make sure your schematic is complete [noparse][[/noparse]if at all possible] before going to creating a board.
To do so, in the VIEW menu - select PIN - to make sure you have visible confirmation that connections are properly made.
Most beginners don't know about this and get an ERC report full of unconnected items even though they appear connected.
Another tip is that the Library requires a lot of browsing in order to learn where things are. Due to European and American cultures being different, names are often not what one expects. It takes a while to learn where the components are.
Finally, think generically and you can easily cheat when the Library doesn't have the exact component you want. As I recall, there is no symbol for a 3-pin resonator. But there are a lot of 3-pin plugs and headers on a 0.1" grid.
"If you want more fiber, eat the package.· Not enough?· Eat the manual."········
NerdMaster
For
Life
1. Get eagle Demo at Cadsoft
www.cadsoftusa.com/
2.Get the PCBGcode ULP and drop it in the ULP folder for Eagle
www.cadsoft.de/cgi-bin/download.pl?page=/home/cadsoft/html_public/download.htm.en&dir=eagle/userfiles/ulp
3. Make a simple drawing in schematic view, then make a board layout from it, arrange parts in a window less than 2" as the demo is limited
4. Read the instructions for the pcb gcode to understand the files types it exports as Gcode(top dril, top traces, etc)
5. When you run the ULP, it will export files you can diretly import into machine software. You can configure the PCBGCODE setup for several machine softwares. I use Mach3, simply load in the file and route traces. Mach3 is free to up to 1000 lines of instructions.
NerdMaster
For
Life
You seem to be starting a new thread which might get a lot more response if you stuck with the Community Supported PCB Milling Machine, also in the Sandbox. Several people there are working on them. Some even have something working.
