bug IO with Sxsim
Hello,
I am a problem. Look
In I/O panel I put ra port = 0101
If ra port is IN, it work good
But in my program the ra port is IN or OUT
If ra port is OUT,
mov !ra,#%0000
mov ra,#$OB
But when I replace ra port IN
mov !ra,#%1111
mov w,ra
The program not look my change and the read of ra port is 0B, not 5 !!
And sxsim look a bug·
· but my program is good.
Jean
If ra port is OUT,
mov !ra,#%0000
mov ra,#$OB
mov !ra,#%1111
mov w,ra
Jean
Post complete working source code and let others help you find out if your code is good. If possible, make a SMALL program that demonstrates the problem.
Thanks, PeterM
The program is a driver for the FT245R ship.
The PC get "1" and the sx put a $0B response.
At the second main loop, the ra port have a persistent information $0B.
For testing the program, set rb.0, rb.2 and ra.0
At the first, the program loop at read_usb.
clear rb.0, and for write_usb clear rb.2
Look ra port.
The sx write $OB, and at the second read_usb the ra port are not refresh. The result is $Ob, not 1.
Jean
···DEVICE· SX28,OSCHS3
··DEVICE· turbo,STACKX, OPTIONX
··IRC_CAL IRC_FAST
··ID····· 'CCD02'···;program ID label
··RESET·· reset_entry··;set reset/boot address
··FREQ·50_000_000
RXF·=·rb.0· ; in. inv
URD·=·rb.1· ; out. inv
TXE·=·rb.2· ; in. inv
WR·=·rb.3· ; out
org·08H
temp·ds·1
data·ds·1
reset_entry··MOV·M,#$0F
··MOV·!RA,#%1111·; Place le port A en entrée/sortie
··MOV·!RB,#%01000101· ; Place le port B en entrée/sortie
··mov· rb,#%00000010
··MOV·!RC,#%00000000· ; Place le port C en sortie
··setb·RD
;··CLR·RB
··CLR·fsr··; Efface la mémoire vive du SX
:loop··SB·fsr.4
··SETB·fsr.3
··CLR·ind
··IJNZ·fsr,:loop
main
··call·@read_USB
··mov·w,data
··and·w,#%00001111
··jmp·pc+w
··jmp·main··; si 0· le SX ne répond pas
··jmp·command
command
; test réponse du SX28
··mov·w,#$0B
··call·@write_USB
··jmp·main
··org·$200
; lecture de 8 bits sur le port USB par le SX
read_USB
;··clr·Sdata
:att··snb·RXF··; rxf = 0, la FIFO est prête
··jmp·:att
··clrb·URD
··nop
··nop
··mov·data,ra··; lecture port a
··nop
··nop
··setb·URD
:fin··retp
; écriture sur le port 8 bits de l' USB
write_USB
··mov·data,w··; data sur le port B
:att··snb·TXE··; si TXE = true, attente
··jmp·:att
··mov·temp,m··;
··mov·m,#$0F
··mov·!ra,#%0000··; ra en écriture
··mov·m,temp
··mov·ra,data··; data sur le port C
··nop
··nop
··nop
··setb·WR
··nop
··nop
··nop
··clrb·WR
··mov·temp,m
··mov·m,#$0F
··mov·!ra,#%1111··; ra en lecture
··mov·m,temp
··mov·data,#0
··retp
end
