Debugging...
Hi Guys,
I am trying to use the BS2 debugger submitted by Martin Hebel.
I have downloaded his software and installed it in my Prop Stick. It is running on Com1 serial port.· I have also downloaded the Basic Stamp II software and used it to successfully test the debug feature on a BS2 SX Stamp kit.
I then moved the serial cable back to the Prop Stick.· Now the Stamp software reports that there is no stamp and the Propeller software reports that there is no Prop chip.
I need detailed instruction on how to use this combination of hardware/software, hopefully conveniently.
Thank you,
Ed
Post Edited By Moderator (Chris Savage (Parallax)) : 11/6/2006 11:30:28 PM GMT
Thank you,
Ed
Who says you have to have knowledge to use it?
I've killed a fly with my bare mind.
BS2 works well now.
Ed Kirkham
