Use a SX-28 as a logic master chip
T&E Engineer
What is the best way to approach in design using an SX-28 to replace some logic chips (e.g. 74HC00 NAND, 74HC32 OR and a 74HC138 3/8 Decoder). Would making up a truth table of the possible inputs and outputs and then simplify it through Kanough mapping be the best approach. I want to use an SX-28 to replace a·few chips. Should I use the logic statement or simply use a bunch of IF THEN statements to the·pins on the SX-28 (Inputs and Outputs) as "individual" chips. Hopefully you can follow·what I am saying.
Summary:
Choice A: Through the use of IF THEN statements (e.g. If RA.0 is HIGH AND RA.1 is HIGH THEN RA.2 is LOW, ect..) within an SX-28, create code to emulate per say individual logic chips·and then connect·them together with wires externally to the SX-28 (e.g. SX-28 RA.0 and RA.1 are inputs·to a NAND and RA.2 is the output)
Choice B: Use Karnough mapping to make one master logic statement using various SX-28 I/O pins to emulate this.
I'm thinking that I may have to use Choice B due to the limited amount of pins on the SX-28.
Does anyone know where I can get a good reference to Karnough mapping as I haven't used it in 10 years since college?
Thanks.
Thoughts and Comments?
Summary:
Thanks.
Post Edited (PJ Allen) : 11/6/2006 1:35:47 AM GMT
- Sparks
