BS2px and PIN 7
Is there anything special about PIN 7 on the BS2px?·
If I change the PIN declaration below to "PSC PIN 7"·the code fails however every other PIN (0-6, 8-15)·works perfectly.· I tested the code on a BS2 and every PIN works as expected.
Post Edited (Mike Gebhard) : 11/5/2006 5:35:25 PM GMT
' {$STAMP BS2}
' {$PBASIC 2.5}
' Set baud for all STAMP versions
#SELECT $STAMP
#CASE BS2SX, BS2P
N2400 CON 1021 + $8000
N38K4 CON 45 + $8000
#CASE BS2PX
N2400 CON 1646 + $8000
N38K4 CON 84 + $8000
#CASE #ELSE
N2400 CON 396 + $8000
N38K4 CON 6 + $8000
#ENDSELECT
PSC PIN 15 ' PSC I/O Pin
buff VAR Byte(3) ' Temporary variable
Main:
DEBUG CR,"----------------------------",CR
GOSUB Get_PSC_Settings ' Check PSC Baud and Version
STOP
Get_PSC_Settings:
DEBUG "Getting PSC Information", CR
SEROUT PSC, N2400, [noparse][[/noparse]"!SCVER?",CR]
SERIN PSC, N2400, 500, Try_38K4,[noparse][[/noparse]STR buff\3]
DEBUG "Baud = 2400", CR, "PSC ver: ", buff(0), buff(1), DEC buff(2)
GOTO N2400_Found
Try_38K4:
SEROUT PSC, N38K4, [noparse][[/noparse]"!SCVER?",CR]
SERIN PSC, N38K4, 500, Baud_Exception,[noparse][[/noparse]STR buff\3]
DEBUG "Baud = 38K4", CR, "PSC ver: ", buff(0), buff(1), DEC buff(2), CR
N2400_Found:
RETURN
Baud_Exception:
DEBUG "Failed", CR
RETURN
·· There is nothing special about P7 on the BS2px.· Is it possible you have damaged the pin somehow?· What board are you using?· Is it possible something on the board is also connected to that pin on the module?
I'm using a BOE and no external circuits. You're right I guess PIN 7 must be damaged. I wired up a simple LED circuit and all pins but PIN 7 function. I'm not sure when the damage occurred. I rarely use the BS2px.
