Basic Stamp 1 Project Board - Breadboard
Hi there,
I really hope someone can help me with this.
I bought a Basic Stamp 1 Project Board, i've looked at the basic code examples and i understand them.
The thing im having a problem with is the breadboard and how to wire it up.
I have a PIR Sensor (http://www.parallax.com/detail.asp?product_id=555-28027) and a motor to test with.
The PIR Sensor has a + - and Signal.
Could someome please give me an idea of how the breadboard should be wired up, i don't understand where the + and - should be coming from.
I read all of the pdf documents from the parralax site but they don't seem to shed any light on this.
Thanks Very Much
Thanks Very Much
·· Tie the – pin to VSS on the Project Board, + to VDD and Signal to the I/O pin you want to use.· You can plug the PIR sensor right onto the breadboard and run jumper wires from there to the other sockets.· I hope this helps.
Thats exactly what i was looking for, thanks very much.
