12 volt 10 amp
Lightfoot
Where can I find a transformer that has a 120 volt primary and a 12 volt secondary? It has to handle 10 amps on the secondary.
Well well, I'm seeing things, three of them.
-Stanley Blystone
-Stanley Blystone
Sid
Sid Weaver
Don't have VGA?
Newzed@aol.com
-Stanley Blystone
This should do it for you:
http://www.mpja.com/productview.asp?product=7846+TR
IMHO $18.00 (US) is a decent price for a 120 VAC to 24 VAC C.T. 10 amp transformer. The C.T. (center tap) on the secondary is what permits you to have a 12 VAC output. In series the secondary would be 24 VAC. When placed in parallel your secondary is 12 VAC.
If you need a simple wiring diagram, let me know.
Bruce Bates
Post Edited (Bruce Bates) : 11/5/2006 9:32:32 AM GMT
Sure, but in parallel, you have a total of 20A at 12v if you use a 4 diode full wave rectifier,
and 10A at 12v if you use a 2 diode bridged-full-wave trectifier..
Also the output voltage will be higher depending on the load placed on it.
Bob
And the problem with that is what?
The transformer exceeds the users ampacity requirement. I've never viewed that as a problem with ANY transformer.
Bruce Bates
<!--StartFragment -->
What is your desired output (rectified, filtered, final voltage)?
No problem at all, just wanted to clarify so he could adjust components accordingly..
