Propeller and the XBEE
I have had the Prop and the Stamp communicating for some time, hardwired.· I decided I would like to go RF to get rid of the wires so I bought two of Martin Hebel's XBEE transceivers, plus an AppBee Mod for the Stamp.· Had to make a little board to interface the XBEE to the Prop but the whole thing is working beautifully.· I can send and receive strings or bytes to and from the Stamp flawlessly.· These XBEE transceivers are jewels - about one inch square with a little whip antenna and $24.00 each.· I got the 1mw XBEE which has a max range of about 100 feet - more than enough for what I need.· I found the 2mm female headers for the Prop interface board at Samtec.
If you're thinking about going RF, have a look at Martin's XBEE units.
http://www.selmaware.com/appbee/
Sid
Sid Weaver
Don't have VGA?
Newzed@aol.com
Sid
Sid Weaver
Don't have VGA?
Newzed@aol.com
Are you using Mikes OS or FullDuplexSerial for your comms? Can you post some sample code? I just haven't had time to do it with my Prop yet [noparse]:)[/noparse]
-Martin
Martin Hebel
StampPlot - Graphical Data Acquisition and Control
AppBee -·2.4GHz Wireless Adapters & transceivers·for the BASIC Stamp & Other controllers·
i would be happy to post some code but my Prop program is quite large and contains many functions that have nothing to do with Stamp communication.· Are you interested in just the part of the code that deals with talking to the Stamp?
Sid
Sid Weaver
Don't have VGA?
Newzed@aol.com
The time is:· 17:14:35· Eastern Standard Time
The time is brought to you via XBEE
I'm going to have a lot of fun with this!
Sid
Sid Weaver
Don't have VGA?
Newzed@aol.com
And I guess you simply plugged it into the same pins the Stamp was directly connected to so you had to change nothing on your program?
Glad it's of use!
-Martin
Martin Hebel
-Martin
Martin Hebel
