support: infrared communication to PC and max 232
the infrared transmit cirucit is builded by using IC555(see attachment).·The circuit·is connected with basic stamp2. The function of the circuit·is to transmit ascii data to another IR transceiver which is connected with PC through RS232 socket.
my questions are that:
1. Is it necessary to use a MAX232 to convert basic stamp·output·from·TTL to RS232 ?
2. if (yes), please give the code example to show how to transmit ascii data.
Thank you very much
specification of IR transmit circuit
baud rate 1200
reception frequency 30 33 or 36 khz
Thank you very much
baud rate 1200
