9V - 300mA AC Adapter with Basic Stamp HomeWork Board
I purchased a 9V - 300 mA AC Adapter from RadioShack and I wanted to connect it to my Basic Stamp HomeWork Board where the 9V Battery connector is. Before doing this however, I plugged the AC Adapter into the wall and measured the voltage with a multi-meter. The reading I'm getting is 11.04 Volts. I'm wondering if this will work without damaging the Basic Stamp board. If not, then perhaps I should return this AC adapter and try to find one with a voltage closer to 9V.· I'm not sure what the tolerance is on the Basic Stamp for the Input Voltage.
Can anyone give me a suggestion or advice on this? Thanks!
Dave
Dave Andreae
Parallax Tech Support·
