Hello,
Has anyone done a bi-directional communication with there BOEBOT and a pc?
I want to control the BOEBOT from programs running on a pc. It would be like using the BOE as a computer interface. Thank for you help.
Thanks for replying, ·
I have been looking into the Microsoft Studio, but I guess the only way the pc will communicate with the BOE is through a Bluetooth link with this software. I was looking more for a USB or a Serial link, since the pc will be mounted directly on the robotic frame. Thank you and I will still try what you suggested.
Yes. You 'talk' out the PC's programming port (RS232 port, or USB port opened as a serial port). You use "SERIN 16, 36864, [noparse][[/noparse]STR InData]" to 'listen' with the BS2, and "SEROUT 16, 36864, [noparse][[/noparse]"Hi!", 13]" to send back.
The "36864" is the 'baud mode' constant (I may have it wrong, you want 9600, Inverted -- look it up in the SEROUT section of the manual).
I thought it might be possable. there is a robot company call WhiteBox Robotics that offers a robot that's primarly a pc.
with the power of a pc and the BS2, might be all i need, if i only can comunicate bi-ditrctionaly. thanks for the info and i will give it a read.
Hello, · ·· I hadn’t realized you just needed a direct connection.· You already have that when you program the BASIC Stamp.· That same connection can be used for bi-directional serial communication as well.·
▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔ Chris Savage Parallax Tech Support
Great,
Thanks for all the help. so I guess it is possable to use the BOE as a I/O interface. I will reread the manual on SEROUT and SERIN. thanks again for all the help.
·· Please check the following link for the Microsoft Robotics Studio which outlines such communication over Bluetooth.· Take care.
http://www.parallax.com/detail.asp?product_id=28118
