stamp identification sequence? — Parallax Forums
Adrian SchneiderAdrian Schneider Posts: 92
edited 2006-11-04 01:32 in BASIC Stamp
Hello everyone
This is actually a question to Parallax:
Did the·identification/response sequences change recently·for some·stamp types produced recently,
eg. a BS2e is expected to return "e"? Is there updated documentation available, I have been away
from the stamps for quite a while?
Thanks & Regards
Adrian
    edited 2006-11-03 15:09
    Adrian,
    ·· The BASIC Stamp Tokenizer Documentation can be found at the link below.· Nothing has changed for quite a while.· Yes, the BS2e should return an ‘e’ after you send and ‘e’ to it, discarding the echoed ‘e’ of course.· I hope this helps.· Take care.
    http://www.parallax.com/html_pages/downloads/tokenizer/tokenizer.asp
  • BullwinkleBullwinkle Posts: 101
    edited 2006-11-04 00:56
    I straced Adrian's stampbc program and noticed the BS2e was actually replying with "ef".
    Adrain, and Bullwinkle, the letter returned is part of the upgrade scheme. So a BS2e of version 1.0 returns an "e" and version 1.1 returns "f". That is what allows the Windows IDE to display the version number of the Stamp on the Identification screen. It appears to reply with "ef" because of the passive echo that comes back from the "e", then the active "f" actually returned by the Stamp. If you want to plan in advance, also allow for the "gh" as possible version upgrades, although it is unlikely to go that far. It is pretty stable, and I didn't know they had made a version 1.1. In the Stache, to make it both forward and backward compatable, the Stache firmware allows for echo response of any letter in the sequence.
    Every Stamp has its own query response version sequence. The BS2pe expects to receive an "I" and then responds with a letter in the set "iIjJkKlLmMnN" depeding on the version and the pin count.
    www.emesys.com/BS2clone.htm#CloneSXe
    Tracy Allen
    www.emesystems.com
