sx52 timers phase
Vertex78
I have written a program in asm that creates a square wave on both of the timers. Now I am trying to figure out how to shift one of them so that that one of them is 45' out of phase with the other.
Here is what I have:
and this is what I want to do:
I thought I could accomplish this by setting up both timers then clearing the counter in timer1 so that it starts creating the timer 1 signal. Then have a delay that waits for however long I want to wait before timer 2 starts up, then clearing the counter in timer 2. It seems that this should work but when I tried it and hooked it up to my scope it did not show any phase change. Is there a way to do this in sx/b? If so I could do as Bean suggested in another post of mine about the timers to look at the listing generated by the compiler to see how its done in asm.
Post Edited (Vertex78) : 11/2/2006 7:44:57 PM GMT
___ ___ ___ ___ __| |___| |___| |___| |__ timer 1 ___ ___ ___ ___ __| |___| |___| |___| |__ timer 2
___ ___ ___ ___ __| |___| |___| |___| |__ timer 1 ___ ___ ___ ___ | |___| |___| |___| |__ timer 2
I thought maybe someone else would jump in here to help you.
On the surface, what you are trying to accomplish and how you are trying to accomplish it seems quite reasonable to me. However, I should disclose that I have not actually tried to use or even read much about the timers! So I may be of little help. With that word of warning, I am willing explore the timer issue with you if you care to post the code you are trying to use.
- Sparks
If this were my project/problem, I would set up some code that would allow me to turn timer two on and off from an external bit. I would then hook up my o-scope probes to watch as I turned timer two on and off using an external physical switch. I would also slow the clock way down initially so that I would have a better chance of having some meaningful (and random) phase delay when I turned the timer on and off.
The idea here is to make sure that you are indeed controlling the timers like you think you are. It's possible that there is some other subtle issue going on. If you keep turning timer 2 on and off while observing (and run at a much slower clock), you should be able to see if you are affecting phase like you think you are. If you're not, then there's something wrong with you handling of timer setup and control. If you are, then the problem is likely in your delay function.
Thanks, PeterM
· Here it is in SX/B. You might have to tweak the PAUSEUS value to get EXACTLY the phase you want.
Bean
"People who are willing to trade their freedom for·security deserve neither and will lose both." Benjamin Franklin
I studied the SX 48/52 timer information last night. Today I looked at your code and the code Bean posted. (Thanks Bean!)
Taking the advise of PJMonty (Thanks Peter!) to slow the clock down, I adjusted the timing of the code posted by Bean so that I could Step/Walk through it easily to see what is happening and when. Since I do not have a dual-trace scope, I decided to use LEDs to observe the output. This worked fine since I was manually stepping through the code and not using a free running clock.
The code that follows is what I used to verify the phase shift between the two timers. (It is Bean's program with timing values that are easy to step though for those without osciloscopes.) You can run the code in the debugger until the breakpoint. Then use the Step/Walk options to observe the timer outputs via two LED's. One should be connected from RB.6 to Vss and the other between RC.2 and Vss. I found that a Walk setting of 3 gives easily observable results.
I am still looking at your code trying to figure out what is not right; but I wanted to post an update since I told you I would work on it.
- Sparks
I checked out your code, line by line. Most of it looks fine to me. I really think it should do what you want... save for the timing. I think the time delay for the phase offset is incorrect.
Some Data:
- 80,000,000 Hz = 80,000,000 cycles / sec
- You are using a 1:64 prescaler. (This means the timers record one count every 64 clock cycles.)
- The timers are set to count 1120 prescaled cycles, toggle the output, then count another 1120 prescaled cycles before toggling the output and repeating.
- A complete on/off sequence occurs every 2240 timer counts or (2240 x 64 = 143360 clock cycles)
Doing some math...80,000,000 (clock cycles / sec) * 1/64 (counts / clock cycles) / 2240 (counts) = 558 (1/sec) = 0.001792 sec = 1.792 ms
Half of that (1.792 ms / 2 = 0.896 ms or 896 uSec) is the duration an output spends being on (or off) during a single cycle. You want to start the second timer halfway through the first half of the first timer cycle. In other words, you want to start the second timer one quarter of the way into the cycle of the first timer. If a full cycle takes 1.792 ms then a quarter of it takes only 1.792 ms / 4 = 448 uSec. I think your delay of 14 uSec is 448 / 14 = 32 times shorter than it ought to be. So you are starting Timer 2 too soon. You need a pause 32 times as great as the one you are using. Therefore the ouputs should have been nearly in phase with Timer 2 being just slightly offset by 1/32 of a complete cycle resulting in a 360 / 32 = 11.25 degree phase shift.
So, the good news is that I think your code should work just fine. You only need to adjust your time delay!
One other minor thing that I noticed was that after setting up timer 1, you clear Timer 2. I do not think this is necessary though it should not cause any problems.
I think that should solve your problem. I learned a lot about the SX 48/52 timers in the process!
- Sparks
Post Edited (Sparks-R-Fun) : 11/5/2006 2:37:12 PM GMT
