Newbie need help on What's a Microcontroller Chapter #3
Hi all,
I am learning What's a Microcontroller Chapter #3: Digital Input-Pushbutton.
I am connecting the LED on·Pin 9 and the input (Pushbutton) on·Pin 14.
In this exercise Pin 9 will go high after the push button is press.
How to make the LED·High or doing other routine only after the Pushbutton is press 3 times?
Let say after· 3 times the button is press·Led on Pin 10 is high.
Please Help.
TQ.
Please Help.
TQ.
·· Essentially you will need to update a counter variable with each press of the button and have a conditional check for when it reaches 3 then make the LED pin HIGH.· Since you’re only at Chapter #3, I would recommend completing the remaining chapters which may give you more insight on how best to accomplish this.· Take care.
1) Declare a variable for counting.
2) Write a command inside·a DO...LOOP that adds 1 to the counting variable each time through.
3) Add a gate keeper that monitors the pushbutton, and only allows the program to move on when the button is pressed.· (Propbably a nested DO...LOOP, check the last activity in Chapter 3.)
4) Add a statement similar to this:
IF IN14 = 1 AND counter =·3 THEN
· '· Do something
ENDIF
Andy Lindsay
Education Department
Post Edited (Andy Lindsay (Parallax)) : 11/2/2006 5:09:47 PM GMT
Thanks to all who have replied.
Finally I got the answer.
Here I attached the code.
' {$STAMP BS2}
' {$PBASIC 2.5}
counter VAR Byte
Main:
counter = 0
DO
· DO
· DEBUG ? counter
· IF IN14 =1 THEN
· counter = counter + 1
· HIGH 9
· PAUSE 500
· LOW 9
· PAUSE 500
· ENDIF
LOOP UNTIL counter = 3
· IF counter = 3 THEN
· HIGH 2
· PAUSE 1500
· LOW 2
· PAUSE 500
· ENDIF
· GOTO Main
LOOP UNTIL (IN14 =1)
Is there any other method?
Thanks again to all of you.
Respect you all.
doing the same this as this:
' {$STAMP BS2}
' {$PBASIC 2.5}
counter VAR Byte
Main:
counter = 0
DO
DEBUG ? counter
IF IN14 =1 THEN
HIGH 9
PAUSE 500
LOW 9
PAUSE 500
ENDIF
'At this point, counter will be 3
'So the IF counter=3 will ALWAYS be true
HIGH 2
PAUSE 1500
LOW 2
PAUSE 500
GOTO Main
'because the previous GOTO will Always be executed, the next loop will never be reached
'LOOP UNTIL (IN14 =1 )
In other words instead of·
Loop until counter = 3 say Loop until counter >= 3
The reason for this is in case the computer does something like 3.01 your covered.
Doesn't happen often but it does happen.
So for what you want I would write it this way.
' {$STAMP BS2}
' {$PBASIC 2.5}
counter VAR Byte
Main:
counter = 0
DO
· DO
···· DEBUG ? counter
···· IF IN14 =1 THEN
········ HIGH 9
········ PAUSE 500
········ LOW 9
········ PAUSE 500
····· counter = counter + 1
····· ENDIF
·· LOOP UNTIL counter >= 3
This is where you need to figure out if something is going to happen only at 3 or not. If its going to happen only at 3 then write this.
·· HIGH 2
·· PAUSE 1500
·· LOW 2
·· PAUSE 500
·· if counter >= 3 then counter = 0
If it can happen anytime then you need to figure out when its going to happen. For example:
' {$STAMP BS2}
' {$PBASIC 2.5}
counter VAR Byte
Main:
counter = 0
DO
· DO
········ HIGH 9
········ PAUSE 500
········ LOW 9
········ PAUSE 500
····· ENDIF
·· HIGH 2
·· PAUSE 1500
·· LOW 2
·· PAUSE 500···
···LOOP UNTIL counter >= 3
You made me see the clear picture.
Since I am a newbie I need people like you to guide me.
You people are really helpfull.
Thanks.
Another way you could do it is to keep counting up with the the counter, and use the MODULUS operator to check to see if the value of counter is divisible by three. Something like this:
IF (Counter // 3) = 0 THEN LightOn
The reason you check for 0 is that modulus returns the remainder of the division operation, so 3//3 = 3/3, 1 remainder 0, 6//3 = 6/3, 2 remainder 0, 9//3 = 9/3, 3 remainder 0, etc.
This means that your IF..THEN block should run on every third button press.
Edit:
Okay, since I recommended it, I thought I would whip something up as an example. Attached is a program using SERIN to detect keyboard presses, instead of a button. You should be able to modify it for a button based on Ch3 of the WaM book. Because it uses SERIN for the input, you may need to manually connect to the debug terminal.
Post Edited (Kevin Wood) : 11/6/2006 7:10:12 AM GMT
