How to tell program
Using a Basic Stamp 1 Rev.Dx I connect to my computer to see what program is loaded into it. I hit Alt.R and the little window comes up and fills up and then says· HIT any key. Of course when I hit a key the window disappears and nothing happens. I thought when I hit run the program would run as I have a debug command.How do I tell what program is loaded in the stamp??
·· You can download a program to the Stamp Module, but you cannot upload the one already on the Stamp Module back into the editor.· You must load the source code from the disk where you saved it.· If you don’t have the original source you will have to write it again.· Take care.
