Led will not blink debug always says running
Hello just got my SX pro kit and dont feel like a pro Ha Ha. when I run the first progam in the Book tut001.src , if I debug the program and open the LED in the I/O pannel the LED Blinks If I Load the program into the Sx chip
the LED does not blink? can take the wire off and drive it High and it will work. the debug control allways says running and you cant walk or run the program with the SX Key hooked up. have tried with the crystal in or out no diff can read the freq at 50 htz·· Thanks David
Think outside the BOX!
Do you have a resonator plugged into the SX-Tech board ? If so you need to remove it while debugging.
Bean.
"People who are willing to trade their freedom for·security deserve neither and will lose both." Benjamin Franklin
I think Ill put the serial cable that came with my SX pro board latter.Thanks David
the NOP three times still no Go ?? Thanks David
If you don't have a resonator or xtal or anything plugged in that is generating a clock, then it is possible your SX-Key is defective. I would double check everything one more time, and if it STILL doesn't work give Parallax Tech Support a call.
Bean.
