SX A/D conversion
First time SX user, not familiar with machine code, former STAMP user and a electronics hacker needs help.·
I'm trying to use the a/d method in the sample code for the SXB on an SX28AC to read the output of a line sensor output to do PID control on the motors of my robot.· I'm using the Vishay TCRT5000 reflex detector.· The code is straight out of the example
I am trying to scale the output in a usable range.· The ckt is attached.
Right now with the resistors shown, the transistor·collector reads:
0.181 vdc with white resulting in .48 ma
3.08 with black resulting in .192 ma
Which sounds like a good range. But the a/d, monitored with the Watch/Poll command in the Debug mode,·starts counting at 0 or 1 @ 0.3vdc on the·collector·and reaches 240 @2.67 vdc, which is really dark grey.·
I would like to have 0·counts = white and 255 = black
My sensor has the emitter tied to gnd on the ckt board, so putting another resisor in the emitter ckt means more cut-n-kludge.· Hoping for some advice that will give a better range in counts.
I'm not following what you want. You're not going to get consistance values everytime.
Bean.
"People who are willing to trade their freedom for·security deserve neither and will lose both." Benjamin Franklin
Is there any place that tells me the voltage range equivalent at Rb.1 for 0-255 counts?
