Dual-Axis Accelerometer with BS2
I'm trying to measure body movement (footsteps) with the dual-axis accelerometer (Memsic 2125 Dual-axis Accelerometer). Does anyone have any idea how to code the basic stamp2 (which the accelerometer is attached to) in a way as to count footsteps with the accelerometer?
kiera.
kiera.
·· It will really depend on how the sensor is positioned as to how it responds to movement.· You may have to connect and LCD Display to see the output and monitor it while walking holding the unit at different angles to see what results you get.· Then you can work out the code based on the results.· Take care.
