Programmable hammer
As the subject... I need a small device to deliver variable force 'taps'; perhaps a solinoid, using PWM, would do this? Is there a more appropriate device?
Mark
Mark
Lee Harker
then comes the obvious safety issues with remote firing such a device.
A servo with a cam pushing against an arm with a spring....the cam would push the arm back until the cam slipped it and the spring flings it back.....
Steve
Lemme guess...making a piano or drum player?
(Frequently heard from other's)
Tommy, I know it wasn't designed to·x, but can you make it·do x·anyway?
I had this grand scheme to make a wind vane from the Memsic tilt sensor. It is a beautiful idea, the tilt gives wind direction and 'tip' gives wind speed. I purchased an eight inch frosted ball (outdoor driveway light type) and plan to put it on a flexible stalk on my roof with LEDs inside to blink out max wind gust (in red) and last gust (in green). So then I got to thinking... Why not a weather station? You know... humidity, temperature, wind, rain, and all that. Then I think, “Why have some bland old LCD hung on a wall as the only evidence of my effort? Why not make the information available throughout the house?” A wind chime 'scale' could be used to tap out codes representing temperature (three low pitched notes, then a code of lows and highs representing the value--or some such). The same for wind, but maybe spacing the notes far apart for light breezes, closer for higher speeds. Various patterns describe 24 hour rain total, etcetera. Of course it would be overwhelming to hear all of it at once, but temperature at 10 after the hour, wind at 20 past... My wife and I collect clocks, the house is a cacophony of dings, dongs, and coo-coos on the hour and the half, but gentle tones sweeping down the stairs seemed like something we'd both enjoy—and learn to ignore or appreciate as moods shifted.
Me thinks, however, that the cost grows beyond my hobby means, and already my scant knowledge is tested. I have the software in the stamp for ‘wind’ (roughly) and already fitting all the functions in one BS2 seems optimistic at best. That means a network of at least two stamps—I’m using a serial link to my PC for an RTC. Costs mount as I look at sensors, consider cabling, and the effort to buy or make PCBs…
At last I considered only the wind vane and a simple chime to start (R/C season is almost over). Smart modules for other functions using cheaper BS1s might allow me to receive pre-digested information and only ‘play’ the received information though the BS2. Now I read about the temperature based error in the Memsic (excellent discussion by Andy in the Stamps in Class->Mini Projects section) and wonder if perhaps I should stick with a more traditional sensor; it isn’t much fun fighting my way through the hardware/ software if I know the results aren’t accurate.
You've already made some baby steps..just make a few more.
Use your single stamp and get each phase of things running on it....then look at purchasing the SX chip. Your code will have to change a bit, but it's a heck of a lot cheaper than a normal stamp, and you can throw these things all over the place and they can send their Wx data back to your main stamp. That stamp could then send the data out to another SX that will feed the LED's and audio sources.
I didn't look, but I think the SX is running sub $10 for sure. The hurdle is the differnet language.
Steve
