Easiest RF link for BS2e
I did a search and found many threads on RFing data to and from cameras and such used with Basic Stamps.· But, I have not found a lot about just linking the serial·line to and from the stamp itself.
I am looking for the easiest, most painless, most transparent RF serial link to use with the Stamp.· Small is nice also, I would like to have it on my bot...lol
Anyone have any suggestions of what to look at first?
T!
T!
I sell 2.4GHz, error corrected, flow control, la-di-da, etc etc., o
TO send data:
SEROUT pin,84,[noparse][[/noparse]"s"]
Or from the PC you can use a terminal window to send a character.
To accept data:
SERIN pin,84,[noparse][[/noparse]x]
IF X="s" Then ....
Also, if needed, flow control can be used so the Stamp doesn't miss data, but the RF unit needs to be configured first, then:
SERIN pin/RTSpin,84,[noparse][[/noparse]x]
There are docs explaining use on the website.
http://www.selmaware.com/appbee
Parallax sells 433MHz modules for BS2 to BS2 and pretty easy to use, though prone to some error as it is not error checked data.
THere's two options....
-Martin
Martin Hebel
StampPlot - Graphical Data Acquisition and Control
AppBee -·2.4GHz Wireless Adapters & transceivers·for the BASIC Stamp & Other controllers·
-Martin
Naturally, as soon as I posted this I found another thread on almost exactly the same subject.
T!
