PINK udp disconnect
OK. PINKy is working for all the basic stuff, but I can't get it to 'see' incoming udp messages. On the variables page, the varST never changes, but on the diagnostics page under the Data Counters button, rx_udp counts up every time I send a packet (Uh...I send the packet from across the room TO the PINK...so, technically, that last sentence should be all about the rx_udp counting up when I receive a packet...so confusing...).
So here's the thing--I don't doubt I could buy another PINK and get the 2 of them to send STAMP inspired udp packets back and forth, but what I really need is to read the packets I'm already sending. Any thoughts on writing these packets to memory? Examples? Examples would be great.
Kalo
Failure is not the only punishment for laziness; there is also the success of others.
- Jules Renard
Kalo
- Jules Renard
·· Have you ruled out the messages being blocked by a firewall?· Quite often that is the case with messages not getting to their destination.· Take care.
- K
- Jules Renard
·· So far about every configuration I have seen involved a Router, so I thought you may have one.· Perhaps there is something else going on.
1 Linksys router (192.168.1.1) serves as DHL gateway for the PC (192.168.1.2) and is connected via straight Cat-5e to a network switch. The switch has 3 devices connected: the router above, the PINK (192.168.1.249) and the GVG Process Frame (192.168.1.218).
The GVG Frame is the source of SNMP Trap Reports (UDP Packets).
The PINK is powered through a BOE using servo connector leads. Connection and Link lights behave appropriately. I have tried communications with the BS2 -> PINK serial lines both connected and disconnected. No joy in either case.
From both the PC and the PINK, I can ping both other devices.
I have attempted the same tests with the router removed from the setup and a laptop replacing the PC. No differences.
Procedure:
The GVG Frame sends SNMP Trap Reports when monitored conditions change. To send a message, I remove and/or replace the incoming video signal at the Frame. When I refresh the NetBurner diagnostic page (http://192.168.1.249/nb_diag.htm?C=) with "Data Counters" selected, the rx_udp counter has been incremented by the number of changes I've made. So far so good.
Reloading the Variables page (http://192.168.1.249/VV_Show.htm) shows neither of the relevant variables (Nb_varBI, Nb_varBM) have changed. In fact, there has been no variable change whatever. Even if the message is completely empty of content (not that I think it should be) the status bit should flip, right?
Obviously, I'm missing something...but I have no idea what it might be.
Thoughts?
Kalo (Not Jules...he's dead...and French...and quite a bit brighter than I)
- Jules Renard
·· Sorry, I though that was your sig-line…Anyway, I can test it on my end at some point this week and maybe have you try some sample code.·
No worries on the sig.
If you can mock something up, that would be great. In the unlikely event you'd like to go so far as using a GVG source, I'm just down the road from you and happen to have a spare :~}
- K
- Jules Renard
While searching for an explanation the the dilemna above, I stumbled across this thread:
http://forums.parallax.com/forums/default.aspx?f=8&m=95149&p=1
and tried out the udpclient program. It works just fine, which tells me a couple of things.
1) PINKy listens on port 10000 for udp and sets bit 5 when a packet is received. Actually, these nuggets showed up elsewhere is the thread, but I was able to confirm them.
2) In order to use PINK for this project, I need to either change it's firmware, change the source's firmware, or set up a PC to intercept each packet and re-broadcast with port 10000.
Blech.
- K
- Jules Renard
