Keypad 3x4 for SX chip
·Could the code from this post see·File link·be modified to work on a
3x4 keypad? If so would you just delete the "A" "B" "c" and "d" in the lookup table, and change the scan lines p0-p2 outputs and p4-p6 as imputs, how would the DIRL= %00000111 is this correct, dosent seem right this code is writen for BS2 when I convert over to SX it gets an error
on X VAR Byte and·i Var Nib is that because the memory is not set up the same on the SX chip.· Thanks Dave
File:
http://forums.parallax.com/showthread.php?p=570329
Post Edited (dbj) : 10/30/2006 4:45:23 AM GMT
File:
