Propstick....soldering questions
cbmeeks
Just received my Propstick the other day and finally got time to solder it together. However when I was checking for solder bridging I found out that pins 9 and 10 for the propeller chip seem to be connected. I can't see where I got solder bridged between the pins. Is this normal? Surely it can't be.
cbmeeks
Coders' Hangout
A place for programmers to hangout!
http://www.codershangout.com
METROID?
Metroid Classic
cbmeeks
Coders' Hangout
METROID?
Metroid Classic
Who says you have to have knowledge to use it?
I've killed a fly with my bare mind.
looks like BOEn and Gnd are connected
one more question though, what pins are needed from the COM port for the IDE/programming, etc.
Thanks again!
Coders' Hangout
METROID?
Metroid Classic
if you have it, just use a straight thru db9 cable, like you would use with an SX-key/blitz or boe/homework board.
Schematic also shows that, also, on A30,31.
I too have a PropSTICK and am using it temporarily in a two Prop design. Found even though those pins are freed after download, the MAX chip holds the line in a state which prevents actually using that line. Not the fault of the Prop, just that one would need to 'cut' the MAX to Prop trace (which I didn't want to do). So used another pair of pins.
Enjoy your work with the Propeller.
Harley Shanko
h.a.s. designn
Coders' Hangout
METROID?
Metroid Classic
Coders' Hangout
METROID?
Metroid Classic
