Communication between BS and a computer
Hi
Are there a good way to make a wireless communication between BS and a computer. I want to build a map for my boe-bot and to make the map good it takes a lot of both computation and space, so I have to do it on a PC. What I want is something lika a radiocommunicationkit between the BS and the PC. Are there som good ones which doesn't cost to much?
Although I am a newbie to modern robotics, I have done a lot of research on this very topic·. . . to no avail, as far as I am concerned. What I really wanted was a WiFi Ethernet module. As far as I can tell, one does not exist.
However, Elexol does have a neat Ether I/O 24 module offered by Hobby Engineering. The module has 24 I/O pins. However, to use it the way I want to, you would have to lug around a WiFi access point on your robot. I have written Elexol about this. They actually wrote back and said it was a good idea (duh) and they were thinking about it (sure).
I will watch this thread to see if anyone comes up with a good solution for you because it sounds just like what I want to do.
--Bill
You are what you write.
It does require two BS Stamps, but it is very easy to do via the SEROUT and SERIN commands.
http://www.selmaware.com/appbee
Parallax also sells 433Mhz and Bluetooth transcievers.
-Martin
Martin Hebel
StampPlot - Graphical Data Acquisition and Control
AppBee -·2.4GHz Wireless Adapters & transceivers·for the BASIC Stamp & Other controllers·
PC -->BS1-->Transmitter Receiver--->BS2
