C# interface
I have searched on the internet and found the interface for code to interface C# to the BS2, my problem is when I run the software and click led on the led flicks on and goes off, it doesn't stay on like I want it to until I click LED off. I am wondering is that a timing issue, if not what issue could that be here is the BS2 code.
1. Put a Return statement in the following subroutines: readInput, doAction
2. Put a Gosub doAction call in the readInput subroutine
3. You can remove the Pause 1000 lines in ledON & ledOFF if they aren't needed. In this example, it doesn't look like they are, since you aren't performing another action after the pause.
Post Edited (Kevin Wood) : 10/28/2006 8:08:31 AM GMT
These kind of programs tend to make assumptions that are case sensitive and become very buggy.
In other words, they are good introductory devices. But using PBasic will always be better supported. Just consider how often the C# is going to keep up with the evolution of PBasic without having a significant base of paying customers.
In the end, Parallax is always be·happy to help you fix the code because you bought the hardware. You are a customer. That also provides you with the PBasic and free downloadable documentation. So you see, you bought the software and the support too.
Generally top notch programers can easily move between several languages. So, I have been learning C, just to read examples that I can program in the SX-Key assembly language and the Propeller assembly language.
I have nothing that I really care to maintian in C, C+, C# or C++.
"If you want more fiber, eat the package.· Not enough?· Eat the manual."········
