Incorporating the basic stamp into a larger breadboard
Does anyone know where there is a schematic for incorporating the basic stamp into a larger breadboard. Al Williams shows a breadboard that he uses on page 6 of his book Microcontroller Projects Using the Basic Stamp but doesn't give any schematics. I couldn't find one on his web site either. He as mounted the basic stamp, cable connector, ect. on a large breadboard which gives him plenty of room for experimental circuits. Also, where is there a schematic to incorporate a power supply to run these experimental circuits so that they do not have to use the power from the basic stamp? Finally, where is there a source for a cable for connecting the i/o ports to an external breadboard. I realize these are simple questions but I have only been using the stamp for a couple of weeks so I am a novice; however, I would like more room to work with.
thanks
helluvawreck
I have found that:
We are never too old to learn new tricks.
We should never be afraid to ask questions.
There are no stupid questions.
We should stay humble and be thankful for our blessings.
thanks
helluvawreck
I have found that:
They offer several products that will be of interest to you...
One is a Breadboard Voltage Regulator Kit
http://www.hvwtech.com/products_view.asp?CatID=194&SubCatID=196&SubSubCatID=0&ProductID=287
The other is their Stamp Stack II Kit
http://www.hvwtech.com/products_view.asp?CatID=90&SubCatID=93&SubSubCatID=138&ProductID=42
