SX/B - Watched Bit not Showing Changes
I suspect Bean will be the best person to answer this, though perhaps I am overlooking something someone else can spot.
I was trying to debug a large program by watching the state of one of my bit variables. In the process I discovered that the bit is changing but the change is not being reflected in the watched variables window or at least not in the manner I expect. (I see no change, It always reads %1.)
I have attached a very small program that replicates the condition I am experiencing. The program changes the state of bit 7 of my first variable. I expect the watched value to change in the watch window as I step through the program. It does not. Have I done something wrong?
If you run the attached program in debug mode until the BREAK statement, then step though it, you should see this condition replicated. I am using IDE Ver. 3.2.3 and SX/B v1.51.03.
- Sparks
- Sparks
watch systemstatus, 8,ubin
it shows up
Perhaps a watch on an individual bit alias is not possible. I can't make it work on a bit alias
Think outside the BOX!
Bean
"People who are willing to trade their freedom for·security deserve neither and will lose both." Benjamin Franklin
Bean - I am using V 3.2.3! Do you get a different result? I tried it again this morning just to double check everything. The bit in the watch window still does not change, though today it was reading %0 always. When I posted earlier it was showing me %1 always.
metron9 - You are right. Using "watch systemstatus, 8,ubin" does indeed show the bit changing. So I am good. I can just use that.
Obviously this is not a large concern. It is just something I saw occurring that differed from what I thought should occur. I wanted to determine whether it was a problem within the IDE or just with my understanding of it.
Thank you for your replies!
- Sparks
I did a little more investigating, and I found that if the bit is in the global memory area (< $10) then it doesn't work. But if the bit is NOT in the global area (>= $10) then it does work.
If you want you can declare some byte variables before the one you want to watch and that will move the bit out of the global memory area.
Bean.
It seemed to me that I had watched a bit variable before without incident, but I was not certain. Thanks for narrowing the scope of the problem. It is easy enough to work around.
- Sparks
