OEM use
Ok guys I have a question that I haven't really been able to find a clear answer to.· My plan is to use the OEM to program EEPROMs and just wire them up to the interpreter·chip allready wired into seperate circuits.· I put together the OEM and it works fine, but im having trouble wiring seperate circuits.· Basically I need to know what all is required to make the system work as a stand alone.· From what I understand all I need to do is conect the interpreter chip to the EEPROM, resonator, and voltage regulator should work, right?
The sepeate circuits do not need to be programmable themselves, because I will simply swap out EEPROMS to change the code.·
A schematic would be great but any help is greatly welcome.
Thanks in advance.
Thanks in advance.
·· Schematics for minimal BASIC Stamp circuits can be found at the following thread.· There are three circuits.· There are two that you will be interested in.· These two have no programming facility, but are the minimum circuit required to run the BASIC Stamp.· I hope these help.· Take care.
http://forums.parallax.com/showthread.php?p=567989
