HELP! Dimming incandescents
Hi all,
I'm new to the Stamp module and I'm trying to find a way that I can program a flashlight battery to flicker in and out as well as dim in and out using the Stamp.· I can do the flickering in and out with the stamp, but I can't seem to dim the bulb unless it is a LED (which are too directional and not bright enough for my purposes).· I was also hoping to run the system off of a battery source-Does anyone know how I can dim incandescent bulbs electronically?· Or must I use a potentiometer?· If I use a potentiometer, how can I program it electroncially as opposed to a mechanical sequence?
Thanks!
Thanks!
As far as using a POT, you can get digital pot IC's that will interface to a stamp.
Steve
If the Stamp doesn't have too much other program to run, you can get a reasonable dimming effect with the PWM command. Use a potentiometer and the RCTIME command to get a setpoint, then use the PWM command to drive a transistor (either a FET or bipolar) which will control the lamp.
Cheers
Tom Sisk
http://www.siskconsult.com
·· I covered doing this as well as posting some circuits in the following thread.· I hope this helps.
http://forums.parallax.com/showthread.php?p=593401
