Bit Banging a Shift-In
I created a Bit-Bang Shift out from the SX28 to the Propeller because the ShiftOut command is too fast for the Propeller using SPIN. It works perfectly. Now I need a Shift IN but for some reason I can't get it to work. Can·someone please give me an example of a·Bit Bang for Shift In Master Clock.
Thanks for any help,
Eric
Eric
movb····· c,data
rr···········gp2················································· ··;move bit into var
for msb first where the bit you want is on a pin called data and gp2 is a variable
movb····· c,data
rl···········gp2················································· ··;move bit into var
Don't know what you mean "in master clock", and you have set the input levels (ie using schmitt trigger will probably·be not sustainable·) to deal with the 3.3 volt propeller output?
bongo
bongo
I do not have an example I can share right now. However, if you will post what you have that works for shifting out and what you are trying to use for shifting in, I (and hopefully others) can probably offer meaningful suggestions that may help.
In general it looks to me (from a previous oscilloscope posting) that you should:
- Sparks
