Source for Linear Optical Encoder?
Bill Chennault
All--
Does anyone know of a source for linear optical encoders with hobbyist pricing?
Thanks!
--Bill
You are what you write.
Thanks!
--Bill
I think I have answered my own question: There is no such thing as a "hobbyist" priced optical linear encoder. Further, there is no such thing as a hobbyist priced linear encoder of ANY kind.
--Bill
I've made "Goldbergian" encoders before by simply mechanically driving a potentiometer, either via rack and pinion on the pot shaft, or via pulleys and cables. Not necessarily very accurate, but functional within it's limitations.
You could also do the same thing with a rotary encoder.
John R.
8 + 8 = 10
I have come to the same conclusion: If I want linear encoders, I will have to build them.
Accuracy? I dunno. I was thinking maybe 32 counts per inch? Does that sound like too much for a home-built encoder? I want to measure the angle between two legs. Actually, in practice, a simple count will suffice. I really do not care about the angle. In practice, the count will tell me what position the legs are in relative to one another.
A pot might work on the axis of the joint itself. I am a newbie and have never tried something like that. (For that matter, I have never tried using a linear encoder of any kind.) If I use a pot, I imagine that I will need to do some AD conversion?
For a bit, I was very excited about the linear encoder technology available . . . until I saw the prices.
Thanks for any input you care to share!
--BIll
Bill, you can get a very accurate linear encoder for not a lot of money by converting inexpensive Harbor Freight digital calipers. They contain a serial interface that is pretty easy to tap into. 6" calipers can be had for $16, 12" ones for maybe twice that.
Take a look here:
www.pcmx.net/gauge/
or start googling variations on dro (digital readout)
What a neat idea! Building the thing is probably beyond me, but I am sure going to give it a hard look. Plus, HF is just a few miles from me. And, I think I can buy the same thing from Grizzly, online.
Thanks!
--Bill
kelvin
Of course, you are correct. When I thought about the data--using my limited knowledge of the Stamp--I thought, "Gee, will the Stamp know what to do with that floating point number?" Then I began to think of ways to just GET the output as an integer and "massage" it.
In any case, it is a neat idea and it got me to thinking out of the box into which I had slipped.
--Bill
BTW, if you have access to a drill press you can take a discarded sprocket and build a simple jig to drill the holes. Just make a spring loaded arm to engage in the sprocket teeth. Rotate a simple drilling table from tooth to tooth and you can space your holes in a nice fashion. A thought just occurred to me. I saw a small sensor just the other day that (On Jameco, i believe) that was a combination sendor and reciver built into one piece that could be used for this purpose. I don't think it was very exspensive. It had a slot in it so a wheel or lever could pass through. There are more exspensive versions of this same type sensor for industrial machinery. I'll see if I can find that part and pass it on to you.
Good luck,
helluvawreck
http://www.swiss.ai.mit.edu/~pmitros/encoder/
http://www.robotstorehk.com/sensors/sensor.html
I believe I will order some of these little sensors myself to see how well they work. I haven't read this article yet but it looks interesting.
helluvawreck
helluvawreck
I have found that:
We are never too old to learn new tricks.
We should never be afraid to ask questions.
There are no stupid questions.
We should stay humble and be thankful for our blessings.
I have built many rotary optical wheel encoders in the past . . . like about 30 years ago. Today, my need is for linear encoders. Rotary optical encoders are cheap. Linear encoders--using any technology--are not. I hope someone proves me wrong, or else I will have to build them!
--Bill
ps Thank you for doing all that research. Tonight, when I have a moment, I will look at those sites you posted.
http://delivery.acm.org/10.1145/1170000/1165895/9103.html?key1=1165895&key2=7552081611&coll=ACM&dl=ACM&CFID=15151515&CFTOKEN=6184618
Basically, they cut a mouse pad into a circle and mounted it on the side of the robots wheel.· A bracket held the optical mouse next to the mouse pad.· As the wheel turned, the optical mouse would track the movement and report back to·the robot controller (an old PC motherboard).
The article·got me to thinking about other applications for the sensors in an optical mouse.· So I·researched (a al google)·some of the chips used to implement optical mice.· They are basically an imager, microscope, and DSP in a single chip.· The imager/microscope·captures an image of the surface the mouse sits on, and the DSP analyzes the images to determine if the mouse has moved.· Depending on the chip, they can be configured to provide serial, PS/2, USB, or quadrature output and can have resolutions of up to 800 counts per inch.·
It should be possible to hack an optical mouse to provide a 2-D linear encoder.· A·microprocessor like a Stamp/SX/Propeller should be able to read a serial, PS/2, or or quadrature output.
I was thinking such a sensor·could be used·to directly measure the motion of an x/y table.· The advantage being that you don't have to worry about gear backlash, wheel/belt slippage, etc.· However, I have no idea how precise and/or repeatable the output of one of these sensors is.· For example, I suspect that if you moved the sensor in a circle so that it returned to its starting position, the reported sensor position/counts would not be the same as when you started.
Some of the sensor chips let you read out the actual image.· Perhaps with a suitable pattern on the working surface (think the dots on the ball in an optical trackball), the image data can be used to improve the repeatablility.
Here is a spec sheets on·an encoder chip:
www.st.com/stonline/products/literature/ds/11894/vt5363.htm
I just found·links to experiments using an Agilent mouse chip for robot navigation.· They use a Basic Stamp.
http://www.contrib.andrew.cmu.edu/%7ettrutna/16-264/Vision_Project/
http://www.contrib.andrew.cmu.edu/~ttrutna/16-264/Vision_Project2/
It looks like all the FP math could easily be handled by the Floating Point Coprocessor V3. However, one wonders, especially me, about straying from the point of what I want to do with the microcontroller: I/O and some other low-level functions. Everything else, like pseudo-intelligence, floating point math, big memory, etc, should be up-loaded to a pc-type device.
BUT, if getting a good (cheap!) linear encoder demanded the use of the fp unit, then I might think about it.
--Bill
Hmmm. I have about all the old HP printers one could want. Thanks for the idea.
--Bill
ps Think hundreds.
I'm totally new to hobby electronics but I find it fascinating - so much so that I just don't know where to start. I've been studying electronics on my own for about 2 months and got my stamp about 2 weeks ago at Radio Shack. I would have gotten it sooner but the store manager said that you couldn't do much with them and that they were just toys. The stamp is amazing to me. Now, since I got my stamp, it's hard for me to study my basic electronics because of the stamp. Bill, do you build robots?
helluvawreck
I have found that:
Your price figure of approximately $400 is amazingly accurate! I managed to actually get pricing from some of the industrial sales people and that pricing confirms everything you said. All I wanted to start with was a ball screw . . . too bad, can't afford it. So, I will settle for building my own. It will lack the precision, but I am confident I can build what I need.
Yes, I have built several robots . . . BUT, it was about THREE DECADES ago. Therefore, like you, I am a newbie and am excited and think that when I make an LED blink using a BS2p24 BOE--which is about 1/10 the size of my original Z80 microcontroller at something larger than 12" x 12"--that I have really achieved something! I am going through WAM and StampWorks, although I think I could skip a lot of it. However, there are nuggets of electronics information contained in both which I have missed out on in the last 30 years and which I cannot afford to skip.
I taught Robotics in 1979. In fact, I wrote the syllabus and had it approved here at the college. It was much like this forum; people helping people. We used a "thing" (kinda looked like a triangle with wheels with the Z80 microcontroller mounted on top) that I bought and built for the execution of student code written in ZBASIC. (I have forgotten the name of the microcontroller. It may have been "ZBASIC Microcontroller", or something.) The microcontroller was not reliable, as it would often reset with a slight flex of that huge board. But, it had reed relays, I/O pins, LEDs, and some other stuff. The main thing, as it is here, is that it was programmable in some version of BASIC.
The class I taught was the most successful class in robotics ever taught by the college. Even after we spent MILLIONS of dollars for equipment and REAL electronics/mechanical/hydraulic engineers to teach. However, I advised AGAINST all this expenditure for one simple reason: Our goal, formed at a higher level than me (back then) was to teach General Motors all about robotics. WHAT A JOKE! At the time, GM was NUMERO UNO in the robotics world. There was NOTHING we could teach them. In fact, I went to Albuquerque to the first (I think) annual Robotics World (or some such) just to meet with the high priests of GM robotics engineering. Although nice guys, they basically told me exactly what I had already figured out.
Today, I am the Dean and CIO of the college (in KC) and thinking about retirement. I not only want to learn modern stuff for something to do in retirement--as if I needed something else!--I am thinking about reviving that old robotics class that I designed and taught, which was one hell of a lot of fun for the students and me, and come back part-time just to teach it. And, thirty years after I taught the first one, I bet the microcontroller will be FAR more reliable! <g>
Obviously, the store manager with whom you spoke did not know beans, much less computers. I GUARANTEE you that the Stamp you bought at Radio Shack has FAR more capability than what I started with!
--Bill
helluvawreck
I have found that:
I have a CNC mill (a small one) that I can make a linear encoder maybe 14" long or so.
What length do you need ?
Here is an example of a 3" wheel encoder I made.
Bean.
"People who are willing to trade their freedom for·security deserve neither and will lose both." Benjamin Franklin
How about taking Bean up on making you an encoder wheel, but have him cut 1/32" teeth around the perimeter.
Then buy an "Incra Jig" which is a linear woodworking jig that works as a precision marking gauge, a freestanding depth-of-cut gauge, a fence alignment gauge and a center finder and other uses.
http://www.incra.biz/Products/IncraGauge.html
It employs two pieces with 1/32" teeth cut along·one face and placed together teeth side in. When you loosen the knob and slide it to length and re-tighten it, they claim a 0.004" repeatability. I have had one for woodworking for years now and swear by it.
Take the two racks apart, customize one and place it on your linear piece, and mount the wheel on the teeth.
Sort of a linear to rotary converter.
Or look at the fence replacement racks (same 1/32" system)
http://www.incra.biz/· (Incra homepage, look for replacement parts)
Just a thought
TT
(Frequently heard from other's)
Tommy, I know it wasn't designed to·x, but can you make it·do x·anyway?
I was offering to make a linear encoder. I'll have to measure to see what the maximum length I can cut is.
I not sure I can make 1/32" teeth. I've never tried.
Bean.
You can get a linear encoder module and strip from usdigital for around $50. They are quadrature and have index. I think this is a reasonable price for a fairly high resolution linear encoder.
kelvin
www.usdigital.com/products/em1-heds/
helluvawreck
I have found that:
Maybe a plastic gear with the proper teeth already on it, then cut the encoder holes and viola~.
But that being said, Kelvins link looks very promising. I think it can be made for less, but $50 without the fabrication hassel isn't bad at all.
TT
Gee, and I thought this thread was dead! Thanks for all the ideas and offers. I need to do more design work and quite frankly, learn more about the Stamp and how to use it before I actually build something that will involve the linear encoders.
But, I am going to bookmark this thread! [noparse]:)[/noparse]
--Bill
Thank you! Those linear strips REALLY interest me!
--Bill
And, at USDigital, this looks good, too!
http://www.usdigital.com/products/ma2/
--Bill
NerdMaster
For
Life
