Any PINK communication examples with the SX and SX/B?
Brian Carpenter
I would like to program·a variable into the pink via the internet and decriment that value with the SX chip each time a switch is pushed.· This will then be updated to the Pink and viewable on the Web page.
It's Only A Stupid Question If You Have Not Googled It First!!
It just is reading continous the pink flags, and if there is a change it look for the variable that is changed. Then i reads that value and send it back to an other variable location in the pink.
Also it works if an UDP message is received, it put the message to the sx memory and send it back to the pink module.
i bussy now to convert that sx program to sx/B
ciao
