Scanning a matrix and incrementing some values
i have been working this evening on the 4x4 matrix program that Parallax has written.
I can make the program work and understand, after much playing, how it works.· I want to be able to take this program farther though.· What i want to be able to do is to have a byte value for each key 0-16.· I want to adjust each value each time that that key is pressed.· For instance, i want an led to light once the 3 key has been pressed 15 times and a different LED to light once key 16 has been pressed 25 times.·The led will stay lit until until the system is reset.· I did not know what approach to take to keep track of these·16 variables·'Key0 - Key15' and then also let the system know what the different key press amounts are for each key.· For instance, depending on the situation, Key0 will be allowed 25 key pressed before the LED is lit but Key12 will only accept 15 before its led is lit.· I am thinking that if i use a variable called LEDS it can be a 16 bit word and after each of the Key counts reach there maximum number they will set a value in this variable.· For instance,· if key2 and key10 have both reached thier maximum value the LED Variable may look like this, 00000010 00000010· Eventual i would like to use the Pink to set teh maximum key values.· When i set up variables ofr each key i exceed the availiale ram. Any ideas will be greatly appreciated
It's Only A Stupid Question If You Have Not Googled It First!!
Post Edited (altitudeap) : 10/22/2006 10:21:18 AM GMT
' ========================================================================='' File...... KEYPAD.SXB' Purpose... Scanning a 4x4 Matrix Keypad' Author.... (c) Parallax, Inc. -- All Rights Reserved' E-mail.... support@parallax.com' Started...' Updated... 05 JUL 2006'' =========================================================================' -------------------------------------------------------------------------' Program Description' -------------------------------------------------------------------------'' This program demonstrates the scanning of a 4x4 matrix keypad. If no' key is pressed the GET_KEY routine will return a value of 16.'' Key values (hex):'' C1 C2 C3 C4'' R1 [noparse][[/noparse] 0 ] [noparse][[/noparse] 1 ] [noparse][[/noparse] 2 ] [noparse][[/noparse] 3 ]'' R2 [noparse][[/noparse] 4 ] [noparse][[/noparse] 5 ] [noparse][[/noparse] 6 ] [noparse][[/noparse] 7 ]'' R3 [noparse][[/noparse] 8 ] [noparse][[/noparse] 9 ] [noparse][[/noparse] A ] [noparse][[/noparse] B ]'' R4 [noparse][[/noparse] C ] [noparse][[/noparse] D ] [noparse][[/noparse] E ] [noparse][[/noparse] F ]' -------------------------------------------------------------------------' Device Settings' -------------------------------------------------------------------------DEVICE SX28, OSC4MHZ, TURBO, STACKX, OPTIONXFREQ 4_000_000ID "KEYPAD"' -------------------------------------------------------------------------' IO Pins' -------------------------------------------------------------------------Keys VAR RC ' keyboard scan portTRIS_Keys VAR TRIS_CPLP_Keys VAR PLP_CCol1 VAR Keys.7 ' column inputsCol2 VAR Keys.6Col3 VAR Keys.5Col4 VAR Keys.4LEDs VAR RBTRIS_LEDs VAR TRIS_B' -------------------------------------------------------------------------' Constants' -------------------------------------------------------------------------Yes CON 0 ' active low inputNo CON 1Dash CON %01000000 ' segment G only' -------------------------------------------------------------------------' Variables' -------------------------------------------------------------------------theKey VAR Byte ' from keypad, 0 - 16row VAR Byte ' keyboard scan rowtmpB1 VAR Byte ' subroutine work varstmpB2 VAR BytetmpW1 VAR Word' ========================================================================= PROGRAM Start' =========================================================================' -------------------------------------------------------------------------' Subroutine Declarations' -------------------------------------------------------------------------GET_KEY SUB 0 ' get key from padDELAY SUB 1, 2 ' delay in milliseconds' -------------------------------------------------------------------------' Program Code' -------------------------------------------------------------------------Start: LEDs = Dash ' dash in display TRIS_LEDs = %00000000 ' LED pins are outputsMain: theKey = GET_KEY ' get a key IF theKey < 16 THEN ' was a key pressed? READ ReMap + theKey, theKey ' yes, remap keypad READ Digits + theKey, LEDs ' output to display DELAY 100 ELSE LEDs = Dash ENDIF GOTO Main' -------------------------------------------------------------------------' Subroutine Code' -------------------------------------------------------------------------' This routine works by activating each row, then scanning each column.' If a particular row/column junction is not active (pressed), the key' value is incremented and the scan continues. As soon as a key is found,' the routine exits. If no key is pressed the routine will exit with a key' value of 16.'' Use: aByte = GET_KEY' -- scans keyboard and places key value into 'aByte'GET_KEY: tmpB1 = 0 ' reset keyboard value Keys = %0000_0111 ' activate first row TRIS_Keys = %1111_0000 ' refresh IO state PLP_Keys = %0000_1111 ' pull-up input pins FOR tmpB2 = 1 TO 4 ' scan four rows IF Col1 = Yes THEN EXIT ' check buttons on column INC tmpB1 ' update key value IF Col2 = Yes THEN EXIT INC tmpB1 IF Col3 = Yes THEN EXIT INC tmpB1 IF Col4 = Yes THEN EXIT INC tmpB1 Keys = Keys >> 1 ' select next row Keys = Keys | %0000_1000 ' clear previous row NEXT RETURN tmpB1' -------------------------------------------------------------------------' Use: DELAY ms' -- 'ms' is delay in milliseconds, 1 - 65535DELAY: IF __PARAMCNT = 1 THEN tmpW1 = __PARAM1 ' save byte value ELSE tmpW1 = __WPARAM12 ' save word value ENDIF PAUSE tmpW1 RETURN' =========================================================================' User Data' =========================================================================' Matrix to remap keypad valuesReMap: DATA 1, 2, 3, $A DATA 4, 5, 6, $B DATA 7, 8, 9, $C DATA $E, 0, $F, $D' Seven-segment digit mapsDigits:' .gfedcba DATA %00111111 ' 0 DATA %00000110 ' 1 DATA %01011011 ' 2 DATA %01001111 ' 3 DATA %01100110 ' 4 DATA %01101101 ' 5 DATA %01111101 ' 6 DATA %00000111 ' 7 DATA %01111111 ' 8 DATA %01100111 ' 9 DATA %01110111 ' A DATA %01111100 ' B DATA %00111001 ' C DATA %01011110 ' D DATA %01111001 ' E DATA %01110001 ' F
