Efficient learning curve?
What is the best way to self teach oneself to program in Pbasic without taking· months to become fairly adequate? Is WAM·THE way to go, or are there other tutorials or methods?
I hardwire (relay and timer logic) my controls and would like to switch over but don't have alot of time if I am to put my next project on a BS2. I have a BOE and BS2P24, and have the remainder of the Bot kit, the Ping))) /w bracket, the digital encoders, and the IR remote·coming in the mail. I entend to use the BOE-BOT to stretch my brain and hopefully provide most of the learning curve.
Thanks Tommy
Thanks Tommy
Since you also talked about controls using relays and timers, the next text I'd suggest would be Industrial Control.
Link to Industrial Control text:· http://www.parallax.com/detail.asp?product_id=28156· Look toward the bottom of the page for the link to the pdf file.
I hope this helps!
I'd strongly suggest the WAM....Parallax has most of their books up on their site for 'FREE'...so take advantage of them. Check out their digital signals book and their process control....lots of good stuff!
cheers
Steve
Brian
That's not a bad idea. I looked at Idec's Smart Relay, and the new products that they have coming out, awesome stuff programmed in basic. These would definitely fit the bill for the job related stuff. That being said, The reason I chose the BS2 (and Boe-Bot) was to dive into the hobby side of it. I will still learn Pbasic, just currious as to the best inclusive immersion technique(s) to accomplish it. Christ(mas) is coming soon and time to make toys for the kids is short.
Thanks for the input so far Desy, Steve, and Truck. It is much appreciated.
(Frequently heard from other's)
Tommy, I know it wasn't designed to·x, but can you make it·do x·anyway?
Brian
p.s WAM is a awsome place to start ,all of basic stamp learning info is on there web site , and can· be·freely downloaded
Post Edited (truckwiz) : 10/22/2006 6:22:01 PM GMT
WAM was written to be the starting point to the series,·but some people start with Robotics with the Boe-Bot first instead, as the first two chapters of the books are almost the same.·Even if you start by working through·Robotics with the ·Boe-Bot, WAM is worth downloading·and reading for·the programming techniques·and ideas.·You can download·both books for·free:
WAM: http://www.parallax.com/detail.asp?product_id=28152
Boe-Bot: http://www.parallax.com/detail.asp?product_id=910-28132
From your list of "toys" it sounds like you are going to have lots of fun.· If you want to see a Boe-Bot project with the Ping))) sensor, check out Andy Lindsay's Stamps in Class Mini Projects threads here:
http://forums.parallax.com/showthread.php?p=560570
-Stephanie Lindsay
Editor, Parallax Inc.
The 2 you might be most interested in are WaM, which follows the WaM text, and the Parallax Basic Stamp Tutorial. Both can be found here: www.parallax.com/html_pages/edu/downloads/downloads.asp
If you don't have PowerPoint, you can download a free reader from Microsoft.
TBot
Your mileage may vary, but I found it to be a really good course.
HTH, Chris
