MOTOR MIND B Capacitors Question
Hello all,
I'm a new microcontroller hobbyist having extremely good luck with using basic stamps for all kind of experiments, and perhaps I'm going to ask an extremely dumb question?
I ordered a BS2-sx and the enhanced Motor Mind B from Parallax today. http://www.parallax.com/dl/docs/prod/motors/MotorMindbMan.pdf
My question is: What kind of capacitor should I be using? And perhaps someone may be kind enough to explain why I need one at all? The spec sheet calls for a 270uf capacitor at the VMOTOR pin tied to ground (showing 12V source in the example) The only ones I have found (on E-bay) are 270uf 100 volt Aluminum radial lead looking types. And the others are AC Motor Starting Capacitors 270-324 MFD UF 250V and also listed are some Rubycon Capacitors 270uf 450V MXC computer grade?
I have no clue what MXC or computer grade actually means, and the rather large AC motor starting caps seems unlikely for this application. If anyone can help me I would greatly appreciate it. I’m guessing the Aluminum radial type with a proper voltage rating is perhaps my Huckleberry?
Thank You!
-J
Post Edited (jhoyoza) : 10/21/2006 7:34:59 PM GMT
Thank You!
-J
Huckleberry hound...lol
Thank you!
