Does the javlin demo board run faster than the bOE board or something like it because i am running a RCTime methods and it comes out with different values. is there a way to fix this..
What is your setup?
Javelin board with javelin and BOE with basic stamp?
Javelin and basic stamp have different time units
so their values would be different.
If you have R and C setup on both boards, these may be the cause
for the difference. Resistors usually have a 5% accuracy and electrolyt capacitors
usually have a 10% accuracy, which means there could be a +-15% difference
between the two RC circuits.
If you interchange the javelins, are the values the same?
That is, the value for a specific board, does that change
when you change the javelin?
Another cause for the difference could be the oscillator on the javelin.
Temperature and·age do affect a crystal.
Hello, · ·· 12V is acceptable, but you have to be careful about going over that because the BASIC Stamp is powered from Vin, and its on-board regulator shouldn’t see more than 12V or so.
▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔ Chris Savage Parallax Tech Support
regards peter
regards peter
·· Not really, although the recommended power supply for the Javelin is the 7.5V @ 1A.
