Logic Level Fet
Hey Everyone,
I'm looking for a fet of transister that will fully turn on with a gate/base voltage of 5 volts, and be able to conduct 12 volts from collecter/source to emitter/drain.· Anyone have a recomendation?
P.S. Curent shouldn't be a problem, only about 800 mA.
NerdMaster
For
Life
NerdMaster
For
Life
·· I tend to use the IRL520.· While it may be a bit overkill for your application (over 9A current) it is very common and inexpensive.· You can run the Stamp I/O line directly into the gate.· I hope this helps.· Take care.
NerdMaster
For
Life
