Need collision detection circuit help!
I’m Building an autonomous mobile robot using a Basic Stamp module and differential drive and I need to build a collision detection circuit using bumper switches. Does any one have a circuit schematic or code·using this technique interfacing it to a Basic Stamp II?
Post Edited (ltmhall) : 10/20/2006 2:41:09 PM GMT
·· Using bumpers would imply that you have already made a collision.· So if you want to avoid the collision altogether you could use IR, Sonar or a combination of both for best results.· We have several examples of using IR and Sonar (PING) in various places.· The Robotics With The BOE-Bot manual shows the IR routines and the Roaming With PING))) code and a few other examples with the BOE-Bot demonstrate how to use Sonar.· You can find these in the Stamps In Class Forum in the Sticky Thread at the top.· I hope this helps.· Take care.
There are many good reasons to have a collision or bumper circuit on your machine. If nothing else, you will learn quite a bit in the "doing" of it. Back in the VERY old days, that is all we had available and I've used them with a lot of success. Today, if I build the "walker" I plan (hope? dream?) to build, I imagine I will have some sort of "collision" detection on the soles of the feet so I will know when a foot "collides" with the floor.
Like you, I am a newbie. But, I have the books! I cannot give advice on circuits because I am not qualified . . . yet. However, I think the circuit you want is exactly like the one shown below (or at least one-fourth of it) . . .
Although I cannot answer many questions, I can say that Vdd is +5vdc·and that Vss is (obviously) ground.·Stamp I/O pins P0 through P3 are configured as inputs. (Get the book, especially if you have only ONE collision detector.)
This circuit was taken from page 94 of the Stampworks book. I have the actual book, but you can download it free from http://www.parallax.com/detail.asp?product_id=27220
Good luck and I am interested in how it works out for you.
--Bill
You are what you write.
Ha! I must be learning SOMETHING because that is exactly why I told him to get the book, especially if he had only one collision circuit!
--Bill
