BS1 to BS2 transfer
I have project the purpose of it is to read a value from light sensor and send this value to the laptop·via BS1 usb then transmite it using Parallax 433 MHz RF modules·and receive the signal on another place of the room by receiver which connected to BS2 and then to a LED
My task is to divide the light sensor reads to five·levels and for each level switch the LED on certain voltage
so what i have already is:
-light sensor
-Parallax 433 MHz RF modules
-BASIC Stamp 2 module
-BS1USB
-Breadboard
what i need is:
-the code needed for BS1 & BS2 to do this task ?
-is it possible to use BS1 & BS2 as i do?
-Do i need DAC or any other components?
i hope to have answers as soon as possible
Post Edited (mzwd) : 10/20/2006 1:35:11 PM GMT
-light sensor
-BS1USB
-Breadboard
what i need is:
Is this your set up?
Light Sensor --> BS1 --> RF Transmitter········· RF Receiver --> BS2 --> LED
Not quite sure why you need your computer as part of this (once the programs are downloaded onto the stamps)?
You can use the RCTIME comand to get a numerical reading from the ligh sensor if your light sensor is a "CdS photocell and capacitor"
You would use Serout to send the data from the BS1 and Serin to receive the data on the BS2
Your program on the BS2 would be a bunch of If-Then statements... how are you planning on controlling the amount of voltage to the LED?· via a PWM command or Freqout command?
As light falls on the CdS (Cadmium Sulfide) photoresistor the resistance falls. In the dark the value given by the PhidgetInterfaceKit is approximately zero. As the amount of light increases the value increases.
With no light the resistance of this sensor is 500K Ohm, at 10Lux the resistance falls to between 10K and 5K Ohm. This resistance is in a voltage divider arrangement with a 7.5K Ohm resistor.
yes it is
to show to the user which level i have ,and maybe i will use the computer as a control panel later for another task or devices as i read in the manual this comman works only with BS2 which is in the receiver side in my project i think PWM command is what i need
This project should be very do-able.
