LCD Display Question
I am going to purchase an LCD screen to experiment with here in the next few days. I am a college athlete and money is really tight, unfortunately. I have to spend my money wisely. Nothing against Parallax or their prices. I wanted to get something about 4x20 (at LEAST 2x20). Ease-of-use is not important. Wondering if the 4x20 LCD ($39.99) is reasonably priced. Should I just shop around for a 44780 and another LCD? Can i find something cheaper? Any comments would be appreciated. Thanks,
Blaine
Blaine
Here is a source (link below) of reasonably priced, surplus LCD's. Make sure you check the supplied data sheet before you make a purchase to ensure that it's HD44780 compatible. Here it the link:
http://www.allelectronics.com/cgi-bin/category/365/LCDs_(Liquid_Crystal_Displays).html
Bruce Bates
<!--StartFragment -->
You can save some money if you use a HD44780 display, but note this requires about 8 I/O lines and is more difficult to program - see Bruce's link.
Another option is a build-it-yourself serial version like Peter Anderson's #117 kit with a 20 x 4 LCD and parts for the serial controller (minus the printed circuit board) for $19.95 here www.phanderson.com/lcd106/lcd107.html
or a non-backlit version with a printed circuit board for $21 here
www.wulfden.org/k107/index.shtml
·· What is wrong with the 4X40 Displays?· They are essentially the same as any other display with the exception that they have two enable lines to cover all 4 lines.· Most have lines 1 and 3 on the first controller and lines 2 and 4 on the second controller.· Other than that it’s all the same.
Blaine
I ordered my first few to try out from Feturlec, I don't know why the price is so different but then I don't know much of anything about LCD's.... (yet)
Good prices on SSR's too.
http://www.futurlec.com/LCDDisp.shtml
Think outside the BOX!
Just felt that for a beginer the 4x40 would be difficult to get to work. Quess I'm just a beginer to because I have been having
a heck of a time getting one to work, bought 2 from Allelectronics for $8.00 apiece. Tried to use two serial control chips to make it work, also tried one control chip and some other logic chip to reroute the enable line. Still no go.
·· I’ve had pretty good luck with the ones I have used in both parallel and serial mode.· In serial mode I too had to make a custom controller which had dual Enable control lines, but it wasn’t too bad.· Were you able to get anything from the display?· Even treating it as a single unit (2x20)?
http://www.epemag.wimborne.co.uk/resources.htm
