Aliases and Modifiers
My understanding according to the Syntax Manual concerning the symbols ".Byte1" and ".Byte0" are identical to ".HIGHBYTE" and ".LOWBYTE."· Is this correct?
Steve
Steve
···· jonw
tempIn = tempIn >> 1 ' remove half degree bit
******tempIn.BYTE1 = -tempIn.BIT7 ' extend sign bit*********
tC = tempIn * 100 ' convert to 100ths
tC = tC - 25 + (slope - cRem * 100 / slope) ' fix fractional temp
******IF (tC.BIT15 = 0) THEN***********
tF = tC */ $01CC + 3200 ' convert pos C to Fahr
ELSE
tF = 3200 - ((ABS tC) */ $01CC) ' convert neg C to Fahr
ENDIF
I am not seeing how this line " tempIn.BYTE1 = -tempIn.BIT7 " moves anything to tC.BIT.15. I could see it putting in tC.BIT.8.
The line
tempIn.byte1 = -tempIn.bit7
does what it says: extends the sign bit. If that bit happens to be a 1, then all the bits in tempIn.byte1 become ones.
Suppose the temperature is +2 degrees. The the DS1620 returns a 9 bit raw value of %000000010.
But if the temperature is -2, then the DS1620 returns a 9 bit raw value of %111111110. In 16 bit twos complement, the correct binary for -2 is, %1111111111111110. The ninth bit from the DS1620 thus has to be "extended" to fill all the bits. So, tC bit 15 is in fact affected if the original value is negative.
Tracy Allen
www.emesystems.com
