SX/B interrupt disable
I have attached a program that can be used as a starting point. My question, after reading through the SX/B help file I did not notice a command or an instruction that disables the interrupt after an option = $xx has been implemented. So, for example, in my program, how would I disable the interrupt while the pulsin subroutine runs, and then how would I turn the interrupt back on.
thanks
Ray
thanks
Ray
If you using OPTION=$88 to enable interrupts then OPTION=$C8 will disable interrupts.
Bean.
"People who are willing to trade their freedom for·security deserve neither and will lose both." Benjamin Franklin
Do you have Gunther's book? As others can testify, it is a very handy reference. On page 225 of the second edition he makes clear that bit 6 of the Option register is the "main switch" to turn interrupts on or off. (0 = Enabled, 1 = Disabled) For your code, this is the Option bit that you need to change.
To turn interrupts on use:
OPTION = %10001000
To turn interrupts off use:
OPTION = %11001000
Those are the same as the hex values given by Bean. I wanted to explain a little how they were obtained. Obviously the other bits in the Option register have meaning as well, so be sure to check those out if they are of interest.
- Sparks
