Programming Two
I have a Prop Stick that is serial and a SX Tech Board that is Serial.
I am so tired of moving the programming cable between the two.
What do I have to buy and what do I have to do so I can keep them both connected and program them as I need to?
Thanks for any Advice,
Eric
Eric
·· You could either get a Serial A/B switch, or you could add a second serial cable and have both connected to different ports.· If you don’t have a second serial port on your computer you can easily add one with our inexpensive USB to 232 adapter.· I hope this helps.· Take care.
http://www.parallax.com/detail.asp?product_id=28031
A/B switches are bulky and a pain in the neck, given current alternatives.
John R.
8 + 8 = 10
