Javelin board expensive
Robot Freak
hello,
I want to buy a robot kit with Java , so I came out to javelin...
Then I looked at the prices and saw that the Javelin Breadboard is very expensive...
I think it's very expensive because the basic stamp 2 breadboard is a lot cheaper...
Why is this ? Only for the extra COM port ??
thank you
Peter van Lith
thank you
Peter van Lith
Lower volume, higher cost. That's the only reason.
that supports the DIP24 footprint. You do not really need
the 2nd com port, but it is handy.
http://www.parallax.com/html_pages/products/boards/programming_boards.asp
regards peter
Post Edited (Peter van Lith) : 10/16/2006 7:58:00 PM GMT
They could build more boards, but if their sales volume doesn't increase, there would still be no savings. In fact, the prices would need to go up, due to the increase in production costs, labor, inventory, etc.
·· Remember, the Javelin can be used on any of our Development Boards which support a 24-pin Stamp Module.· This does not reflect the popularity of the Javelin module itself.
That said, I would like two see two things incorporated,
1) More speed
2) Less cost
Thus far, I've been able to accomplish what I've needed to. One does need to think about their program and make sure it is effecient. Likewise, the serial communications, which has nothing to do with the javelin, is slow.
Does anyone know if shiftout would work better than a uart and if one could use shiftout and go straight to usb or ethernet?
receive at 28800. The bottleneck in the throughput speed is due to the java virtual machine
that interprets java byte codes. This throughput limit also applies to shiftin and shiftout.
The throughput limit is about 1000 bytes/second.
The javelin runs at 25MHz clockspeed. The sx48 on the javelin module can run at 75MHz
but that triples the power consumption which exceeds the onboard switched regulator
specifications.
I have modified the original Uart class to use a public char array rather than a private int array.
http://tech.groups.yahoo.com/group/JavelinCode/files/Javelin%20Stamp%20IDE/lib/stamp/core/
If you want to use this modified class, rename the original Uart.java to Uart.java.org and
download the modified Uart.java
Because I used a public array, this modified class allows you to access it directly
which may help to increase throughput, because a ram-to-ram copy can be skipped.
regards peter
My main point in the serial communications wasn't actually referring to the javelin, more so to the serial comms itself. Even at 57.6, it does take time to any amount of data.
You bring up something very interesting though. Can one overclock the SX48? Would it be as simple as providing power and replacing the resonator? Or would one have to change the actual interpreter?
and power the javelin via its 5V pin (leaving Vin disconnected).
If you double the oscillator freq to 50MHz, then the javelin
clock tick becomes 4.34usec and all baudrates and other timings become doubled.
(eg. 28800 becomes 57600).
You won't be able to program the javelin because the
programming baudrate would also double, although it might
be possible to change that in the javelindirect source.
Another possible programming problem is writing to the onboard eeprom
because the required write delays are shortened
and may become too short.
Obviously, any attempt to do such an operation will
void the warranty of the javelin module.
regards peter
Post Edited (Peter Verkaik) : 11/18/2006 9:17:34 PM GMT
