Error 44 Address XYZ not with in tho lower half of memory page
Hello!
1.
Yes,·I have checked all threads on this topic but still can't find the error in the source code.
2.
I am using the latest version of the SXB compiler·"1.50.01 -- 05 JUL 2006"
3. I declared all subs as recomended by parallax
example:
FirstSub SUB
SecoundSub·SUB
LastSub SUB
Is there any rule about the order of the Sub declarations, maybe the longest at the top and then descending
Is the any oportonity to force·the SX/B compiler to arrange the code in a propper way? Somebody mentioned the ORG-Statement, but this seems·to be valid for assambler only.
1.
2.
example:
FirstSub SUB
SecoundSub·SUB
LastSub SUB
The latest compiler is 1.51.03.
SUBs need to be declared before any other code (except interrupt code).
If your interrupt code is lengthy, then do this:
INTERRUPT
GOTO HandleInt
abc SUB
xyz SUB
HandleInt:
' Put interrupt code here
RETURNINT
Bean.
Don't mistake experience for intelligence. And vis-vera.
