ultra sonic distance sensor
I have been playing with the Ultra sonic sensor to try and detect a moving object.
I want to be able to tell whether it is coming closer, moving away or staying still.
using the code:
LOW Ping
PULSOUT 6, 5
PULSIN 6, 1, distance
distance = distance ** 2251
running this code twice and then comparing the value of distance. The problem is I need to round off the value of the VAR distance. Otherwise I get a slightly different answer even when things are not changing.
The DEC4 command is just for debug and does not round off the value.
Any suggestions?
using the code:
LOW Ping
PULSOUT 6, 5
Any suggestions?
If you will provide us with the entire program, or more of it than you've provided, I'm sure we can offer some suggestions.
Bruce Bates
<!--StartFragment -->
x· con [noparse][[/noparse]make this the amount of the sensitivity you want]
read the distance
store the distance value in a variable called "prior_distance"
check_sensor
·········· Read the distance
·········· store the distance value in a variable called "current_distance"
···········difference = current_distance - prior_distance
·········· prior_distance = current_distance
·········· if difference is > x then go to big_difference
·········· goto check_sensor
big_difference:
········· do what you want
As an option, you might want to consider averageing a sequence of pings. I used this code in one of my projects:
I didn't need the full resolution of the PING, so i reduced the ping result by 100, making it fit into a BYTE variable insterad of a word variable. I then accumulated 10 samples and took the average of those 10 to get a stable (non-jittery) distance measurement. Hope this helps.
Vern
