Tip41 Emitter voltage issue
Hi all,
I am building a basic H-Bridge and I have been having some issues with the output voltage of a Tip41 NPN power transistor. I put my H-bridge together and found that the output voltage is always ~5v, when the voltage applied to the collector is 10v. I have no problem switching the emitter "on"·by applying power to the base, but its always ~5v that is output from the emitter. Any ideas why this is so? I thought the Tip41 would output what is applied to the collector. Maybe this is wrong? I am no electrical engineer..
PS: I do not think there are any issues with the Tip41. I tried a fresh one with a simple circuit, 5v on the Base, 9v on the Collector, and the Emitter output ~5v.
I need ~9v from the Emitter.
Any help is appreciated.
These transistors are current driven, not voltage, so I'm a bit concerned when you say you've put 5 volts on the base.
Also, with npn's its usual for the emitter to be tied to 0 volts.
Cheers
Tom Sisk
http://www.siskconsult.com
When I mentioned applying 5v to the base, I was referring to a seperate "experiment" to see if it would output (Emitter) the voltage on the Collector, when it was "switched on". It also output ~5v, and somewhat proved that my H-Bridge was ok.
My understanding was that a power transistor is used to switch on a voltage seperate from the control electronics. Maybe I am way off here, but that is what I thought. But no matter what I do, the emitter is always ~5v.
Generally speaking how would I get the emitter to ouput the same voltage as is on the collector? Even a simple circuit would be helpful here. In my "experiment" (not the H-bridge), I have a couple of volts going to the Base, 10v on the Collector, but the emitter is ~5v. Any newbie mistakes here (apart from the volts on the Base)?
Does it sound like I have something like my ground tying wrong? Such as transistors in the wrong direction (cathode)?
Thanks again. I appreciate you taking the time to respond.
I have a few H-Bridge schematics already. What I was looking for was a very simple schematic showing how to get 10v out of a Tip41. I have seen an H-Bridge like the one you posted (NPN and PNP).
The thing I am searching for is; I have ~10v on the Collector, shouldnt that be enough for it to output 10v on the Emitter? I am out of ideas as to why it is dropping 5v somewhere along the line...
Perhaps this (see attached) is what you're on about?
[noparse][[/noparse]Note -- RLcould be a motor.· Try experimenting with a high-value resistor at first, 10K or more.· RB could be, at this point, 1K or so.]
I will hook this up later today and let you know how I go. My "experiment" circuit was similar and that was getting ~5v. That said "similar" is not close enough, so I will hook this up exactly and see how many volts I get on the Emitter.
Any help is appreciated!
Are you sure the diode is not in backwards ? That would cause a large current to flow through the transistor (assuming it IS an NPN).
Bean.
"People who are willing to trade their freedom for·security deserve neither and will lose both." Benjamin Franklin
·· One of the most common mistakes I have seen with the TIP41 is that some people connect it like a 2N3904, where the leads are Emitter, Base, Collector.· On the TIP41 though (from left to right) they're Base, Collector, Emitter.· Do you have them wired correctly?
From the schematic (transistor smoke.jpg) I posted do you see any newbie mistakes, because it is smoking the Tip41's?
Edit:·Just tested·switching the direction of the Diode (1N4004) and its still smoking...
Post Edited (stamped) : 10/18/2006 8:12:56 AM GMT
Bean.
