PropStick setup
new Propstick isn't identified by the IDE.· Known good cable, also tried a Prolific USB to serial converter neither worked.· Scope shows activity on a28 and a29 on powerup, so looks like the propchip itself is working.· Reset is at 3.3v, A31 and A30 show no activity not hooked up to the pc.· Does the com port parameters need to be setup?·
No com port parameters need to be set. When you attempt to identify with F7, it lists the ports it tried. Is the port you're using one of them? Also, since you have a 'scope, check for activity on A30 and A31 during the identify. And finally, make sure that nRST is getting a negative-going pulse during this time.
James L
Thanks.·
Phil
p.s. Wish there was more technical info on the chip, lots of questions aren't answered.
