VGA terminal for a linux router
hello propeller fans,
i want to use a propeller as a VGA terminal for a linux router (for example WRT54G with OpenWRT).
The Board of the router has +3.3V rx tx gnd. Can i direct connext rx and tx or shoud i use 100 ohm resistors ?
Is there a sample programm, that puts keyboards echo at screen and serial output and displays received data on screen ?
Thank you
Thank you
There are several sample programs included with the Propeller Tool and installed when you install the program. Have a look in the demo folder. There's at least one that does most of what you want. You probably want to use the hires VGA text driver and the FullDuplexSerial driver.
that works
